3 pole or 4 pole isolator? | on ElectriciansForums
Discuss 3 pole or 4 pole isolator? in the UK Electrical Forum area at ElectriciansForums.net
W
wozzit99
Hi
When installing a 3 phase distribution circuit what determines the type isolator to use ( 3 or 4 pole ). In other words does the neutral have to be switched?
Cheers
Hi malcomsanford
The earthing system is a TT. As a matter of interest what isolators would i use for other earthing systems tncs, tns?
The installation is a distribution circuit 3 phase feeding a 2 way 3 phase dis board.
Cheers
Just a thought what about if the service is tncs but you cant export the earth to another building so making that part of the system TT
Can you still use a 3 pole isolator at the service end?
Reply to 3 pole or 4 pole isolator? in the UK Electrical Forum area at ElectriciansForums.net
For a TN system neutral is deemed at earth potential.
All good thanks, still trying to retire but still finding myself busy as ever. Hope you're well.
