3 separate dimmer switches controlling one light. | on ElectriciansForums
Discuss 3 separate dimmer switches controlling one light. in the UK Electrical Forum area at ElectriciansForums.net
Kent
Hi, client wants lights dimmed at 3 separate points controlling one light, I don’t think it’s possible without a smart system etc, any thoughts?
I believe Standard rotary dimmers can't be parallel up, you have one dimmer and then normal switches
there are loads of smart switches now that fit on a normal back box if they want to go down that route
The Varilight v pro smart dimmer can do this. They look like a normal dimmer but you need a master unit and then as many slaves as you need, and can be dimmed from any switch.
That's a really useful steer. I wasn't aware of these. And they are not 'smart' (ie not wi-fi) which is a blessing.
just one comment - the spec sheet for the master says max two slave units ('Dimming from up to 3 locations'). Don't know if that is still current.
Much as I love Quinetic stuff and use it a lot, I have had mixed results with the dimmers which seem to be rather fussy about what they work with, so it's always worth doing a trial with just one before buying a load of them.
Personally, i dislike dimming lights anyway, but i know others are keen on this.
Reply to 3 separate dimmer switches controlling one light. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a smart lighting system for ambient lighting in a "traditional" kitchen dinning room it's a big area. I want to be able to put...
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
