3-Speed Single Phase Motor Wiring | on ElectriciansForums
Discuss 3-Speed Single Phase Motor Wiring in the Talk Electrician area at ElectriciansForums.net
KSA
Hi, all.
I need your expert help in creating the internal wiring diagram of the motor with the following information we retrieved.
I have attached a diagram showing:
A. Motor external wiring diagram
B. Wiring Resistances
C. My diagram for main winding only
I am missing how to include the orange and yellow wiring to the main winding (assuming my diagram is correct; if not, kindly correct).
Thanks in advance.
Best Regards.
[ElectriciansForums.net] 3-Speed Single Phase Motor Wiring
Unless I am missing something, orange is connected directly to blue, yellow is connected through the 51 ohm capacitor winding to brown. Supply on blue and brown makes a regular PSC motor with the (blue-brown) winding fed directly from the supply and the (yellow-brown) winding fed via the capacitor. White and red are the taps for the other speeds.
Reply to 3-Speed Single Phase Motor Wiring in the Talk Electrician area at ElectriciansForums.net
Hi, Thanks for that, you learn something new almost every day! Regards Griffey
I really can't see a problem with it assuming there is a neutral there.
