3 switches 1 light problem! | on ElectriciansForums
Discuss 3 switches 1 light problem! in the Australia area at ElectriciansForums.net
E
ezzy99
Howdy,
Moved into our house over a year ago and have only just found out we have a problem with the hall lights. There are 3 single switches in the hall that run a ceiling full of spots. The problem is that occasionally I turn on one of the switches (can be any of the three) and the lights do not change. If they are on and the switch is pressed they stay on and vise verser. Its starting to frustrate me now as it seems to be when I come home from work in the night and turn the switch at the front door on it doesnt work. When I come in from the garage and use the switch at the back of the door that doesnt work. It seems to follow me about the very switch i want to use doesnt work so i need to randomly press the 3 switches to get them to work!!!!!!!! Please help!!!
Cheers
ezzy99
Maybe connected up wrong at the back....or there may be damaged insulation on the conductors and its shorting across.....switch wire to switch wire as its bound to be quite congested behind that 3 gang switch plate.........
You have 2 No 2 way switches and 1 No intermediate
You probably have mixed up connections in one or other or even all of them
This was a thread on the subject ,there are many more
http://www.electriciansforums.net/e...rum/42324-two-way-intermediate-switching.html
Look at the wiring diagrams and compare to yours and alter to suit
You may need a spark if you cant understand the layout
I didn`t read the first post properly des...I agree with you it sounds like mixed up wireing.......
I suspected that was the case Glen,being a sadistic b-----d I just let you carry on
[ElectriciansForums.net] 3 switches 1 light problem!
I fixed an issue alongs these lines a while back. Customer had changed the switches and had got the cores/cables mixed up. Took a little while with my tester and wander lead to get it sorted.
If nothing has changed then the problem is likely to be broken insulation or, as you are switching a lot of downlights, you may be getting one of the switches welding itself closed with the current and would require a new switch at the appropriate position.
If things have changed then the wiring should be checked, safely with the power off and a tester.
I attach a picture of the standard wiring diagrams for lighting taken from the TLC website for reference.
View attachment lighting WiringDiagrams.pdf
Thanks guys for your replys (Glennspark, Des56) wasnt going to look back on here tonight was going to give it a couple of days. What a great forum. Literally only got in from work so to dark to look into things tonight but I plan to investigate further. Not sure how I post pictures on here yet but Ill probably post a few tomorrow showing the back of the swithces. Again thanks for your replys.
Thanks for the reply (murdoch, richard burns). Just got back from work so to dark to really investigate plan to have a look at the back of switches and possibly take photos to post. Cheers
Reply to 3 switches 1 light problem! in the Australia area at ElectriciansForums.net
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
