3-way or 4-way switch dimming with Shelley2 | on ElectriciansForums
Discuss 3-way or 4-way switch dimming with Shelley2 in the DIY Electrical Advice area at ElectriciansForums.net
DC Metro
Hi there,
This is my first post as I am new member here. I would really appreciate if anyone can recommend wiring a smart switch called Shelley2 dimmer into an existing circuit that I have here at my house with three switches controlling same set of lights, two of which are 3-way and the third one is 4way. I thought the 4way is the last one in sequence so it is the light source but now I am not sure about that. Also there is no neutral in the box. Any questions or recommendations will be really appreciated. Here is the link for shelly2 wiring with and w/o neutral: Google Image Result for https://hometechhacker.com/wp-content/uploads/2020/12/ShellyWiringOptions.png - https://images.app.goo.gl/ZyPXGmgTGgHp1RKu5
Reply to 3-way or 4-way switch dimming with Shelley2 in the DIY Electrical Advice area at ElectriciansForums.net
I found out the answer from another forum...here it is, yes This will be your neutral for the receptacle. Add a pigtail and connect to silver...
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
