This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed ground wires as one of the switch leg/loop travelers on a 3-way. Obviously, this is completely wrong and a fire hazard, so I decided to try to rework the mess, and ended up with a big headache.
Here's my question - can you help with this wiring puzzle?
Is it possible to wire this configuration with only two 12-2 between the two ceiling fixtures? I believe it takes five wires (not four) and that's why wiring was done improperly using a ground wire.
Here's a summary of the circuit (see attached picture):
See attached photo.
Am I missing something, is there another way to wire the circuit? I believe I'm one wire short between ceiling box 1A and 1B -- 5 wires are required not 4.
My backup plan is to simply replace the 3-way switches with single poles switch loops and control lights 1A and 1B separate. But, before I go this route, I thought I would see if anyone can solve this wiring puzzle.
Thank you in advance.
-NNMark
- Two ceiling boxes (1A + 1B) controlled by two 3-way switches (1A + 1B).
- Power enters the ceiling box 1B with 12-2 cable
- Switch 1A is connected Ceiling Box 1A with 14-3 cable
- Switch 1B is connected Ceiling Box 1B with 14-3 cable
- Ceiling box 1A and 1B are connected with two 12-2 cables
- Ceiling box 1A also houses two additional 12-2 cables to power another ceiling fixture #2 with a single pole switch #2 loop.
See attached photo.
-NNMark
