300watt towel rail | on ElectriciansForums
Discuss 300watt towel rail in the Australia area at ElectriciansForums.net
wales
anyone ever put one of these on a lighting circut in a bathroom.
been to look at job and this is what had been done.
bathroom was on its own circut 6amp rcbo b type
only pulling about 1.3 amps can handle it, bit like putting one of those heating fans on the lighting circuit, bit strange seeing it wired like that, most wire it off a sfcu to the towel rail.
Reply to 300watt towel rail in the Australia area at ElectriciansForums.net
im just assuming that they are designed to be surrounded by material, and would heat to a certain amount, spreading the heat into the material...
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
