30ma for existing 16mm T+E submain ?? | on ElectriciansForums
Discuss 30ma for existing 16mm T+E submain ?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
tomchester999
Hello all!
I am working in a property with 3 old rewirable fuseboards, each fed from mcb's in a modern consumer unit at the incoming supply.
We want to change the 3 fuseboards to 17th ed RCD etc. However, as the 16mm T+E is less than 50mm in the wall I wonder whether I should protect each submain at the source with 30ma RCD or RCBO or just leave it as it is (currently 100ma at source)
Obviosly if it were to trip 2 floors down it would be really annoying, but do I need the protect the 16mm in the wall? Running new supplies in armoured is out of the question unfortunately..
thanks in advance for any advice!
did a similar job in some flats. RCBO for each 16mm fitted in main CU. 2 years on and no tripping problems. in this case, though, the landlord lives on site, so not a problem to reset. also, it saves fitting RCD protection in each sub-main.
I would be seriously tempted to protect with 30ma at the source purely to protect the 16mm t&e. It may as you say be a nuisance should it trip at the source but better that than the alternative
Reply to 30ma for existing 16mm T+E submain ?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
