30ma RCD test times pass | on ElectriciansForums
Discuss 30ma RCD test times pass in the Australia area at ElectriciansForums.net
L
lukesparky123
Hi there can anyone tell me what are the pass results for a 30ma rcd ?
x1/2 x1 x5
thanks alot
luke
you're reight IQ. i put 300 then had 2nd thoughts. just like 2nd marriage was worse than the 1st. LOL. should have looked it up.
arrrghhh, that's where the 200 came from. really must open the brb more often. must be my age! LOL. as long as i can still spell " altzeimers" i think i'm still functioning 80%
spot on. that is the max. alllowed. actual trp times are usually much less. typically 20-30ms at x1, 10-15ms @ x5. anything below the max. is a " pass" . when you test, you test at 0 and 180. record the highest results.
Reply to 30ma RCD test times pass in the Australia area at ElectriciansForums.net
It can also mean lasts or continues for two years.
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
