30v on disconnected cable? | on ElectriciansForums
Discuss 30v on disconnected cable? in the UK Electrical Forum area at ElectriciansForums.net
England
Recently pulling in some new lights in my kitchen, using the original feed in I ran 2 strappers and cables for 8 downlighters.
Turned the circuit on and checked with my volt stick that the switching was correct and noticed the volt stick was going off no matter what position the switch was in.
Tested with a fluke and seen 30v to earth and neutral- even when I'd disconnected the cable?!
Can anyone shed any light on why I might be getting this voltage?
Cheers!
I went to install some spotlights in a house (owner was retired GPO spark). I was getting voltage on the earth. I couldn't understand why until I asked the owner if he had swapped any cable; he told me that he'd replaced a length from the CU to a junction box with, "a second hand, good piece". Swapped this length of cable and the fault went. I stripped the t+e in question and found the insulation of the phase had broken (repeated bending/too tight a bend) and connected with the earth.
Reply to 30v on disconnected cable? in the UK Electrical Forum area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
