N
nearlynew
I was originally going to have a double oven installed so the electrician installed a dedicated cooker circuit with a cooker control unit, 6mm t&e and 32amp mcb.
The plan has changed and I will be having a single oven instead so I will need to replace the 32 amp mcb with a 16 amp. Is this something I'm allowed to change myself or must I use a fully qualified electrician to do it?
Thanks for any advice
