32amp 3 phase switch disconnector ( switch fuse) | on ElectriciansForums
Discuss 32amp 3 phase switch disconnector ( switch fuse) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
W
Wardy1980
Just a quickie.. Can I change the fuses inside the switch fuse to 63amp from 32amp?
As I am feeding a distribution board off the switch fuse..?
Because I have a 3 phase distribution board feeding a 32amp switch fuse which then feeds another distribution enclosure which has a 20amp radial, and a 16amp, 10amp and a 4amp breaker feeding machinery!
Reply to 32amp 3 phase switch disconnector ( switch fuse) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
He needs to first be able to confirm the design current (Ib)
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
