32amp socket connection for temporary cabin | on ElectriciansForums
Discuss 32amp socket connection for temporary cabin in the DIY Electrical Advice area at ElectriciansForums.net
Wakefield
Can anybody help please.....I need to connect a cabin electrics to the house, appreciate normally long term this would be via fuse board direct, however I just wish to connect to the house using 13amp plug. The minimum draw from the cabin is 20amps, if I used a split socket 32amp to twin 13amp sockets and plugged into two house sockets would this work? Or any alternative suggestions? appreciate any help for this to effect a solution rather than direct to the main fuse board.....don’t wish to use generator if at all possible..thanks
Absolutely NOT
The splitter you are referring to is commonly referred to as a widow maker.
This needs connecting properly and rcd protected.
If this is a domestic property it will also need notification to building control unless a part p installer is used.
Absolutely NOT
Was suspecting this would be the answer...thanks for advice ...need a plan B...Thanks again...
Reply to 32amp socket connection for temporary cabin in the DIY Electrical Advice area at ElectriciansForums.net
I think I've found the answers to my questions... I can just do a straight forward wiring i.e. connect the 3 wires from the armoured cable to...
An example of the long term race to the bottom of quality of work in our industry, IMHO.
