35 Amp Fuse | on ElectriciansForums
Discuss 35 Amp Fuse in the Australia area at ElectriciansForums.net
P
Pockets
Does anyone know the maximum Zs for a 35 Amp cartridge fuse? any info would be great and where you found it.
bs1361? bs88? by interpolating the time/current tables in bs7671, the current required for 0.4 sec. disconnection is approx. 220A. so max. Zs would be 230/220 = 1.045 ohms. nearest i can come up with.
Reply to 35 Amp Fuse in the Australia area at ElectriciansForums.net
The same socket can be used for different appliances, such as kettles... which will draw more than 5A The size of the cable determines how much...
All the lamp post cutouts I've ever seen have a twin swa gland plate built in to the base.
loz2754
L
