M
MattyKHZ
Having room for 16 south facing panels I got hung up on efficiencies and started to look at 16 of the Sanyo HIT-N240SE10 panel making a 3.84KW system.
I was recommended for similar money to go for 17 of the HIT-N235SE10 panel as this would be 3.95KW.
Yet from a configuration point of view 16 panels would look best so even though less efficient I decided on 16 of the older 250W Sanyo HIT panel.
Inverter was going to be the SMA 4000TL but I hear that you have to restrict to 16A or get DNO permission.
Just wondering why people would go for larger than 3680W output if you cannot use it or get FIT for it if the DNO will not accept it? Or is it a question of time and if the FIT changes were not rushing things you would be able to apply for running more?
As time is of the essence and say if I can get the Sanyo in 250W panel, would I be better with the 4000TL or maybe the Solar Edge SE4000 system and power optimisers. Would teh 4000TL not get approved by the DNO or take too long to? I guess it depends on the area I live in (Tamworth) and how many existing installs there are in the area.
If the efficiency and power optimisers in the Solar Edge system are beneficial is the extra expense justified if again you are restricted to 3680W. Why do people go for 4KW if you cannot link it to the grid at full capacity?
It seems to me that you would be paying extra for generation capacity that you cannot use!!!!
