380 volt | on ElectriciansForums
Discuss 380 volt in the UK Electrical Forum area at ElectriciansForums.net
E
eagleeye
A friend of mine has just bought a pizza oven and the rating looks like 380 volt single phase at 4.5kW. Any idea how I can connect this to our current supply ? It's definitely single phase as the thick flew coming out of the unit is only 3 core (live, natural, earth)
Flex Possibly ??????????????????
Is this a Commercial oven?
Is it new?
If not have you looked inside to see if what the flex is connected to?
Have you looked inside to see what the 3 core is connected to?
If not try continuity from oven casing to "Earth" in the flex.
Photo of the Data plate would be good.
[ElectriciansForums.net] 380 voltspec plate on unit. I think its classed as a commercial unit yes
notice it says 4.5kW/h though so this can't be the actual power rating of the unit ? and also say electrical connection 380 ? is that some kind of connection or is this the voltage rating ??
Sounds more like it must be a two phase system, though I would not expect it for ovens.
I cannot see how you can get 380V ac single phase, but L1 and L2 instead of L and N could do it but the supply would be unbalanced.
I've come across them before, along with commercial washing machines and of course some welders
It could be, 4.5kw is not unusual.Though the information plate is a bit vague! I'd expect to see the current rating on the plate and the voltage marked as 380/400v? Is there no paper work? It might be an Idea to go online search the model and make of the unit and check out the supply requirements?
Is this the oven model? https://translate.google.co.uk/tran...//www.mirror.es/index.php?lang=en&prev=search
It shows it as 4.5kw- 380v -3 phase
HP 14T
Electric pizza oven
  • Pizza oven series "Snack"
  • Dimensions 860 x 810 x 440 mm
  • Sleeps 4 pizzas Ø 30 cm
  • With built -in thermometer
  • Thermostatically controlled up to 400 ° C
  • Refractory stone floor, removable
  • House insulated with rockwool
  • Exterior, sides, roof and back of steel painted especially for high temperatures
  • Front and doors in stainless steel AISI 430
  • Wheeled support available (optional)
EXTERIOR DIMENSIONS
860 x 810 x 440 mm
INTERIOR DIMENSIONS 620 x 620 x 180 mm
ELECTRICAL POWER SUPPLY 380 V (three - phase)
THERMOMETER if
POWER 4.5 kW
FLOORS
CAPACITY PIZZAS
4 pizzas Ø 30 cm
SUPPORT Optional
NET WEIGHT
74 Kg
GROSS WEIGHT
86 Kg
What colours are the individual wires in the flex? and what size do you estimate the wires to be csa
Reply to 380 volt in the UK Electrical Forum area at ElectriciansForums.net
How did it go?
