3amp FCU Tripping | on ElectriciansForums
Guest viewing is limited
Discuss 3amp FCU Tripping in the UK Electrical Forum area at ElectriciansForums.net
SO1
customer asked for a 2g socket and single light to be put into her outhouse which was connected to her kitchen, as there was no power there i had to take a spur off the existing kitchen radial circuit into the outhouse, i took it from the spur to a 13amp FCU onto a 2g socket then onto a 3amp FCU then onto a single 60w lampholder. everything worked and tested fine when i left but within 24 hours the customer rang me and said the 3amp FCU had blown. any ideas?
Plenty of ideas, some of them will probably get me told off by the moderators.
Have you been there and carried out any testing to establish what has happened or why?
I'd start with confirming that the fuse has indeed blown and not the lamp
You would be surprised how often I fit light bulbs and they are knackered. I always fit Osram Eco halogen lamps, I picked up three, two didn't work. Another time I fitted two, just as I was leaving they switched it on and one packed up.
Lamps not bulbs you plant bulbs, really uk
Hi SO1 - your post history shows you were taking your level 3 about 3yrs ago, can we assume now as you are taking on paid work you are not DIY or even Trainee but an Electrician?
When you did the work did it all test out correctly as is required for the cert' provided to the customer?
If so then I would assume the lamp blew taking out the 3amp fuse, has your customer tried putting another lamp in?
Darkwood beat me to it for a change :ciappa: I am also curious about your competence level and what stage you are at quals wise, once we know those things we can answer accordingly, I just hope you are not still in training and doing paid work while unsupervised.
Reply to 3amp FCU Tripping in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
You too? I thought I was in a unique position:anguished::coldsweat:
Recommended Sponsor News
Hi everyone,
Email
Time zone
Last seen
3amp FCU Tripping
