3map power shower on lighting circuit | on ElectriciansForums
Discuss 3map power shower on lighting circuit in the Australia area at ElectriciansForums.net
R
Rayelect
I have been asked to replace a broken power shower. Looking at the wiring it is wired into a 3amp fused switch in the loft and then into a junction box on a what looks like the lighting circuit. Is this ok being only 3amps it isn't drawing much at all?
why has no one replied? is this a wind up?
showers normally draw a lot more than 3 amps and should be on their own circuit
Well, you replied ;)
& the OP did say Power Shower - 3A max is quite normal for these, altho it`s preferable to supply them via fcu fed from RFC
Reply to 3map power shower on lighting circuit in the Australia area at ElectriciansForums.net
Question 1 do you prefer buttered, salted or sweet salted? I'm guessing salty 😜 1. Auto range multimeter (used on mains before when testing the...
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
