T
TPES
Big factory, huge 3ph supply, been split into smaller individual units.
I will be taking out one of the extreamly old 3ph panels and replacing it with a split load single phase board. Isolating the other 2 phases. Running single phase only. The reason being there is only a 20a radial and 2 ligthing circuits off this huge panel.
As this is clased as industrial premises can someone tell me exactly what HAS to have RCD protection.
I plan on putting the radial circuit and toilet lighting circuits on RCD side and office lighting on main switch side. Is this ok to do??
Is there a reg that states lighting in offices has to be RCD protected?
