B
badwolf
Hi there, heres hoping i can borrow some of your time to corroborate an nic inspector's advice.
The job is to move a 3p+n supply 30m to an adjoining building through a duct in the ground. The customer needs over 70A per phase for his equipment. So coming from the existing kiosk with 3phase cutout with suppliers isolator, the nic inspector has asked for an mcb to be fitted in the kiosk, along with the existing isolator.
So this means fitting a 100A mcb and keeping the 100A isolator? is this correct, surely a 3pole switch fuse would be better?
Any ideas?, thanks.
Any ideas?, thanks.
