3rd Amendment CU's Cable Entry | on ElectriciansForums
Discuss 3rd Amendment CU's Cable Entry in the UK Electrical Forum area at ElectriciansForums.net
Nottingham
Ive changed several CU's all with rear cable entry,
Ive just been to look a job to change a CU with the majority of the cables surface clipped twin and earths...what is the preferred method on cable entry into the CUs?
Ive been looking and found some cable glands that are suitable for twin and earths like this:
Sprint Cable Glands - https://www.tlc-direct.co.uk/Main_Index/Cable_Accessories_Index/Sprint_Cable_Glands/index.html
What are people thoughts?
All advice appreciated
With that many cables, I would use either of the two methods already mentioned. You could also consider using plastic trunking, using top or bottom entry, more knockouts.
Never used them, but Hager Design 30 CU's have oblong knockouts for trunking use.
Hager design 10 have the square/ rectangular knock outs in the top for cables entering in pvc trunking and come with grommet strip.
Tho I'd use thicker grommet strip as hagers is poor.
Reply to 3rd Amendment CU's Cable Entry in the UK Electrical Forum area at ElectriciansForums.net
