1valiant
Am I missing something here or is it just plain bad luck? I've recently tested a fuseboard and the RCD failed (MEM A100HE 100AMP 30Ma RCD). Sent off for a new one and it failed got another failed again.
Checked multi-tester on another board, tester works fine. It's on a TN-S system, there's a 16mm earth clamped onto the incoming leading straight to the fusebord, the earth clamp is tight. all bonding is good. Am i missing something or have I just come across a batch of dodgy RCCB's.
Cheers.
Darren.
Cheers.
Darren.
