C
Coleman
Hello just a question
If you have a 4.1kw array installed capacity system dose this qualify you the high rate tariff because you work out the declared net capacity of the inverter to be lower for eg 3.7 at 16amps?
The DNC is not relevant in determining the appropriate FIT rate - it is the TIC that matters. In simple terms, if the maximum inverter output is less than the kWp of panels installed then the TIC is equal to the maximum inverter output. It is worth understanding the definitions.
Regards
Bruce
> 4.0
Thread Tags
Coleman,
BruceB,
