Discuss 4 core fp200 ring circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks, When you say offers none of the protection characteristics what exactly do you mean by that ? Do you mean if it is designed for MI then FP doesn't meet the design criteria that MI would give ?
Came across a 2.5mm fp200 4 core cable used as part of a ring today, am I right in thinking this isn't an acceptable method as there will be only 1 earth wire in the cable ??
nah they are a ring as the conductors are connected in two separate pairs in the joint and not all together.
Reply to 4 core fp200 ring circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
