4 Pole 100A 300mA RCD ???? | on ElectriciansForums
Discuss 4 Pole 100A 300mA RCD ???? in the Electrician Talk | All Countries area at ElectriciansForums.net
E
eskimo39
Does anyone know if it is possible to get a 4 pole 100A RCD (3L & N) with 300mA trip?
Also needs to have time delay.
Not too much to ask is it?:D
Cheers
Cheers
Not sure if you can get the unit all in one but have fitted mccb's with external adjustable (30ma to 1000ma) and adjustable time so setting up is all your choice, merlin, hagar,square d, etc make some configuration of this for their front end mccb boards
Reply to 4 Pole 100A 300mA RCD ???? in the Electrician Talk | All Countries area at ElectriciansForums.net
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
