dkpramanik
For a LT panel which have two incoming 5000A ACB from 3phase, 3MVA Dyn transformer & 630A ACB from 3 phase, 250kW Black Start DG set and have several outgoing 3 phase, 100A-300A MCCB for remote distribution panel and have some single phase load.
Could anyone pls advise which type of 3 Pole or 4 Pole ACB and MCCB should I use for the LT panel as per IEC standard?
What are the advantage and disadvantage of using 4 pole vs 3 pole?
