DomB
Hi all,
We've been asked to quote for a ground mounted system to run along the length of a 1.2m high wall.
I've had a look at the Console system (Thanks MarkC) but could really do with the panels being mounted in portrait. The Schuco "flat roof array" system might work too. But I wonder if making a frame out of treated timber which we bolt Schuco mounting rails to is an option. It wouldn't be that much different to how the Schuco in-roof system works, i.e. rails bolted directly to the rafters; we'd just be building the equivalent of the rafters..
However, the PV commissioning tests do ask for confirmation that the "Array Frame & Material is Corrosion Proof" - I wonder if we'd fall foul of that? I guess the whole thing is about it lasting 25 years.
Any thoughts much appreciated
Cheers
Cheers
