I'm planning to install 4 50 watt LED flood lights and three PIR's the idea is to link the switched output of the PIRs so if one is activated all of the lights come on. I also plan to link the switched output to a wall switch so that the customer can turn them all on manually.
It is possible that just one PIR is activated so all of the current will be running through the one PIR. I have read somewhere that LED floods have a high start up current.
If I use PIR's rated at 1000 watt incandescent and 500 watt fluorescent will that be ok ?
