I've a pal looking for a little help.
They want to install outdoor lighting (a mix of CFL , GU10 and possibly LED Fittings) within 4 pir zones controlling approx 4 - 6 lights per zone. All the wiring is going back to a garage where a system unit will be mounted. He wants to then mount a control pad or switch unit in the house that will provide all zones with separate On, OFF & PIR control options. So a zone can be either switched on (bypassing the pir) for example for a barbecue, another zone off and the another 2 zones operated by the PIR. Is a DALI system the only way out of this or is there something a bit more residential. Any recommendations for a system/brand greatly appreciated.
