40A Flow Switch | on ElectriciansForums
Discuss 40A Flow Switch in the UK Electrical Forum area at ElectriciansForums.net
Wales
Hi everyone
I am looking for a water flow sensor/switch to turn on a 11.5Kw shower.
The flow sensor/switch must be capable of handling 40A for a period of upto 2 hours of use.
Does anyone know of such a thing if one exists?
Hi everyone
Think you will find that showers are not designed to run for this length of time.
I should of explained in the op.
the issue is this property is using a 5L (under sink) hot water tank to fill a bath, sinks, shower (non electric). The current tenants won't use the shower!
they have asked me to find away of filling the bath with hot water, I have looked at demand hot water heaters but can't find anything suitable.
I think the 2hrs was an over guess but could happen as tenant has been known to leave hot water tap on for hours.
has anyone else got any other ideas?
So basically you need instantaneous hot water heated by electricity in a sufficient quantity to fill a bath before the first water goes cold?
I hope this property has 3 phase.
What wrong with an old fashioned hot water tank with an immersion heater?
Reply to 40A Flow Switch in the UK Electrical Forum area at ElectriciansForums.net
I went to look at a job like this a few years ago. My customer had a rental house, where there was an upstairs bedroom that had a newly built stud...
    • Informative
My older card has it but my newer card doesn’t
