Hi all, our summer house had a FuseBox consumer unit fitted last year and the guy who did the work has retired. nothing wrong with the install however my wife wants an outside light fitted and would be best to run some white 20mm conduit to the CU as it would blend in when we decorate. the CU only has a 40mm knockout on the side. is there a 40mm to 20mm reduction gland or is it best to drill your own 20mm hole. Just interested in best way and will be hiring in an electrician but locals are so pulled out with work atm
