E
Ely Sparks
Hi,
Hopefully someone can help me with the following:-
Having recently carried out a Inspection on a installation I came across the following problem-
After isolating a ring main at the RCBO, I still have approx 40v at the socket outlets. There is another ring main, where after isolating that circuit, the 40v clears at socket outlets. I assumed it was something like a shared neutral between the circuits, but after checking for continuity on the neutral between the two separate rings, they don't seem to be interconnected.
My Megger 1552 won't carry out a No Trip Zs test or RCD test on the socket circuits either, I'm assuming it's related to the above problem. My tester is fine, I checked it on another installation.
Any advice to point me in the right direction of solving the problem would be appreciated.
Thanks.
Thanks.
