uksparks
Hi,
Im just in the process of making some PAT test leads up, 16 and 32A, 110v and 230v with IEC end and plug etc, just going to make some 415v adapters up and just wonder, does the single Line conductor on the 230v plug end you plug into the tester connect to all three phases in the 415v plug?
I presume it does, I just wanted to check before i wire it up and put bridges in or not. I cant see that It wouldn't bridge between on three phases as it would make no sense otherwise.
If anyone can confirm it would be appreciated thanks, same question goes to 4 and 5 pin.
Thanks,
Some I made earlier...
Thanks,
