4C + E required for stats | on ElectriciansForums
Discuss 4C + E required for stats in the Central Heating Systems area at ElectriciansForums.net
Dorset
Looking at a job with under floor heating and the stats require 4C + E, what would you use? I was thinking of running in two PVC twin and earths.
Anyone else done something similar? Just after different options/opinions.
I would run in two 3 core +E to allow for any future wiring. You are pulling in cable anyway so might as well make any adaptations easier later on
2x 1.0 T&E or a 5 core 0.75 flex.
I can't see any future change in stat technology requiring more cores.
I'd guess the ones you are wiring have a floor sensor or night setback sensor to need an extra core??
4c & E is not so common, but i use 5 core flex.
Just out of curiosity - what brand of thermostats are you installing?
Thanks guys.
It's a Nu-Heat system with set back.
I did think about using 5core flex but perhaps 1.0 5core. Just doesn't feel right installing flex over that distance etc. I must admit, having all the cores in one cable would be aload easier.
Regards
I was right about a night setback being involved then :)
In the past I've usually gone for 5 core 0.75 flex for these kind of stats, some of them specify it.
There's nothing wrong with installing flex these days, the 2metre rule disappeared many years ago.
Reply to 4C + E required for stats in the Central Heating Systems area at ElectriciansForums.net
T
600mm tile layout - will this work or look odd? Hi, i'm undertaking all of the tiling in our project. I have two different types of 600mm tiles...
tombo83
T
On a small generator I wouldn't want to risk using diversity as they are not quite as forgiving as a mains supply and can very quickly fail when...
