View the thread, titled "4kW system" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
solgen
Hi,
What is the right value to put on MCS and DNO forms for net capacity?
The total peak power of the panels is 4kW and the inverter is 96% efficient although limited to 16A.
Is it 4.0 x 0.96 = 3.84kW
or
3.68kW
Cheers
As maximum available panel power is greater than maximum continuous inverter power output then:
TIC = DNC = max continuous inverter power output = 230 x 16 = 3.68kW
Reply to the thread, titled "4kW system" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
