An instalaltion 4KWp in a new build house with a 3 phase supply.
Would you:
Install a 3phase inverter? not sure they are made for such small instalaltions,
Install 3 single phase inverters and a monitoring device to cut them all out if one phase drops.
Install as a single phase system and therefore lose some of the output to the grid, as only one phase in the property will be able to use the generated power? It is unlikely that during the day that they will use 4KW on any one phase but over 3 phases it is likely that they would use most if not all the generated power.
Has anyone experince of this?
Would you:
