Hi,
I’m trying to replace a cable to an oven. The oven is 3.6kw total connected load. It requires approximately 25m run and the cables are clipped direct to a wall. I was going to use a 2.5mm cable but when I opened the isolator it has 4mm cable in there.
I think my calculations are correct in that I can run it with 2.5? Could someone just confirm that I’m not going mad?
Thanks,
Andy
Thanks,
Andy
