4mm spur | on ElectriciansForums
Discuss 4mm spur in the UK Electrical Forum area at ElectriciansForums.net
R
redface
dose anyone use 4mm tw/e now to supply sockets on 32a mcb as a spur if so what distance can you go in plastic 3 compartment trunking reference method c is 37A but methord B is 32A
now as there is only 1 cable in trunking. so i cant see why it drops 5A just to being inclosed in plastic
or dose everyone still use 2.5 ring circuits
no not home work i just put a 4mm tw/e spur of sockets about 70m in 3 compartment trunking on a 32A MCB and am just wondering if i need to make it a ring or weather you would or not it is only for a few computers and microscopes i could lower MCB i suppose .
So you have already carried out the work, but you're not exactly sure whether it is correct?
What calculations did you carry out regarding circuit loading, EFLI, voltdrop etc. ?
As the BGB says historically the floor area served has been limited to 75m "SQUARED".
The reason there is a 5a CCC between cables installed method C and B is due to the cable heat dissipation simple
EDIT So your NOT fine.
Reply to 4mm spur in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
5K
