4pole 3phase | on ElectriciansForums
Discuss 4pole 3phase in the UK Electrical Forum area at ElectriciansForums.net
A
aaelectric
Hi,
was wondering when you need to use a 4 pole isolator on main switch for 3 phase. Is it just for tt systems?
also do you need 4pole isolators on appliances ie 3 phase cookers etc or is 3 pole ok.
thNks
I think this came up when neutral conductor became a live conductor whilst the live conductor became the line conductor, so line and neutral are live and have to be isolated together at at least one point.
Reply to 4pole 3phase in the UK Electrical Forum area at ElectriciansForums.net
Better/Smart/intelligent/expensive generators require two earth spikes set ~10-15m apart. They check the resistance between spikes and will...
Yes, relatively common, especially in rural areas, once upon a time. The bare overhead lines would be hard-drawn copper and supported on porcelain...
davesparks
