5 / 6 Core Flex Advice Needed Please | on ElectriciansForums
Discuss 5 / 6 Core Flex Advice Needed Please in the UK Electrical Forum area at ElectriciansForums.net
Hi Everyone
Don't often get involved in wiring up central heating! I have been asked to install new Honeywell ST9400c to replace ST7100 on a Y plan (Mid-position valve). The new programmer requires a 5 / 6 core flex.
I can get 5 core every where, but I feel over sleeving the earth is bad practice, so how do you guys get on that are doing it all the time?
Any advice would be much appreciated
Sorry if this is a basic question:dunce2:
T&E
Reply to 5 / 6 Core Flex Advice Needed Please in the UK Electrical Forum area at ElectriciansForums.net
W-plan pump run on Son recently moved into a 20 year old house with what appears to be a W-plan system using, I think a Worcester Bosch Greenstar...
davidwf
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
