P
Peter Woodford
guys,
this may sound stupid why are there chop blocks rated at 5amp and a mcb can be rated at 6amp
Discuss 5 amp chop blocks in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
5 amp choc or connector block is a means of joining cables together, it is rated at 5 amps due to the amount of copper used during its construction and its size.
A MCB is a device designed to protect the wiring in the event of a fault, it is rated at 6 amps to protect the cable with the smallest CSA in the circuit, usually this will be the 0.75mm flex drop on the lighting pendant.
Connector block is available in allsorts of sizes, it is usually not possible to fit cables in which are capable of handling current in excess of the rating of it, however i have seen it done.
Reply to 5 amp chop blocks in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
