5 amp sockets | on ElectriciansForums
Discuss 5 amp sockets in the Australia area at ElectriciansForums.net
Y
YTSOxford
Guys,
Is it good practice to put 5 amp socket outlets for table lamps on its own breaker and not linked with the standard lighting circuit??
Cheers.
Reply to 5 amp sockets in the Australia area at ElectriciansForums.net
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
By code the washing machine needs its own 20 amp single pole GFCI circuit, the dryer needs a 30 amp double pole breaker and using # 10 wire. Your...
