J
Jabbajaws
Hi there everyone,
I was examining my sister's Consumer Unit, the other day and did a clamp meter test on the meter tails and also the earthing conductor.
Line conductor = 8.3A
Neutral conductor = 7.8
Earthing Conductor = 0A
Now l confess to being puzzled on this one as l thought that the line & neutral conductors should be more or less equal. One cancelling out the other.
There is no current flowing through the earthing conductor, so thats a difference of 500mA, that seems to be disappearing somewhere.
Does anyone has a possible explaination for this odd reading that im getting?
Im thinking that there is a loose neutral perhaps, somewhere in the house...
Hi there everyone,
What make and how good a model is the clamp-on ammeter and when was it last calibrated?
Look at the spec of the clamp ans see what the +/- tolerance is. You may also get a slight variance in readings depending on where the cable is within the clamp.
Could also be an inductive / capacitive load in the circuit? Then the currents won't add up with your clamp meter.
Thanks for the input. Im afriad its a cheapo one l use just for messing about with at the mo. Yes l am getting repetitive readings the same, but as pointed out it could l suppose, be the clamp meter itself and/or also capacitance, which l shamefully admit that l didnt even consider...
You've answered your own question in the second comment "a cheapo one"
500mA adrift.....
Thread Tags
Jabbajaws,
ian.settle1,
