5100w ikea oven with 15 metre distance to CU | on ElectriciansForums
Discuss 5100w ikea oven with 15 metre distance to CU in the UK Electrical Forum area at ElectriciansForums.net
sparkybrum
Hi just fitting an Ikea double oven with total rating of 5100w, there's a 15m distance from oven to CU and its clipped directly to the wall but is Laid by some ring main cables for only a short distance to the consumer unit...my calculations suggest 4mm cable with 22.17amps, so I was going to use 4mm connected to a 32a mcb.
Anyone suggest an alternative
Is there any insulation involved over the length of the cable run?
Will the DP isolation switch also have a socket outlet?
I would use 6mm tbh as a minimum for a cooker circuit, although there is sometimes not the need as 4mm is sufficient for the loading
Would the 45a dp switch also have a socket outlet on it?
in brummingham? you must be joking. their women would then want to plug in a TV and then dinner would never get done.
Reply to 5100w ikea oven with 15 metre distance to CU in the UK Electrical Forum area at ElectriciansForums.net
That was my saying not long ago about TNS to PME system. I would be nice you can ring up the DNO, will the systems being up graded, there is a...
This charger doesn't support rear entry from the looks, only bottom entry, hence that. Unless they make a white sheathed SWA, I would still need...
