ste mac
How do we stand with using the round pin 5A sockets on a lighting circuit with a 6A MCB?
Will the sockets be classed as overloaded (probably only under fault conditions) due to being protected by a 6A MCB?
Is the only way around this to place a fused spur before each 5A socket or would it be better to run a separate circuit for the 5A sockets from a 5A FCU below the Consumer unit from a dedicated MCB?
Do we rate these as 100W per fitting when calculating circuit loading?
A customer has specified about 20 of the 5A sockets on a rewire job I'm pricing for, & requested the sockets to be switched by light switches, so I'm just trying to get my head around which would be the best or most cost effective way of wiring.
