6 Inch Can Light Retrofit Bulb Wattage Advise | on ElectriciansForums
Discuss 6 Inch Can Light Retrofit Bulb Wattage Advise in the DIY Electrical Advice area at ElectriciansForums.net
dennisd
Indiana
Hello,
We would like to update the lighting in our Great Room that measures 28' x 18'. The ceiling has two 6 inch can lights on a sloped ceiling above the fireplace that is 13 feet high. We are considering retrofit LED Gimbal replacements but are unsure about the bulb wattage. Does anyone have a suggestion on the wattage or other lighting options? I have attached a photo. Thank you!![ElectriciansForums.net] 6 Inch Can Light Retrofit Bulb Wattage Advise
Hello,
We would like to update the lighting in our Great Room that measures 28' x 18'. The ceiling has two 6 inch can lights on a sloped ceiling above the fireplace that is 13 feet high. We are considering retrofit LED Gimbal replacements but are unsure about the bulb wattage. Does anyone have a suggestion on the wattage or other lighting options? I have attached a photo. Thank you!!View attachment 56002
Dennis there should be a label saying max wattage. Good luck my friend
Reply to 6 Inch Can Light Retrofit Bulb Wattage Advise in the DIY Electrical Advice area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
