C
carlejo
Hi Guys, new to the forum and would appreciate some advice.
I have a 4000 g pond and I'm intending to heat(temp control really) it this winter as it's far more beneficial for the koi.
I have a 6kw heater and pond is approx 40 mtr from the main consumer unit.
Would it be ok to use 10mm T&E wired directly into 40 amp outlet of RCD and then place it in protective casing en route to shed, where the heater will be.
Basically it's the length of run I'm worried about, will the cable suffice.
ps.... cable will be placed through very strong ducting and fixed to wall approx 9' high, so no danger of anyone touching it anyway
cheers
Carl
cheers
Carl
