6 or 10 A lighting circuits | on ElectriciansForums
Discuss 6 or 10 A lighting circuits in the Australia area at ElectriciansForums.net
A
adam.h
This has probably been covered before, but whats every ones preference on 10A lighting circuits?
If doing a new install would you rather have two 6A circuits or 1 10A (or even 16!), what with everyone wanting to have downlights these days.
Not sure how correct this is, but I understand that when the haligen bulbs 'blow', 6A breakers are more prone to trip, which is why some prefer to put them on 10A?
You say 2x 6amps or 1x 10amp mate, in a new install, "houses " you have an upstairs circuit and a downstairs lighting circuit, so always 2x 10amps for me dude, + 1.5 T+E as well, we never use 1.0 like some.
Reply to 6 or 10 A lighting circuits in the Australia area at ElectriciansForums.net
Hello What was the conclusion of your problem?
By code the washing machine needs its own 20 amp single pole GFCI circuit, the dryer needs a 30 amp double pole breaker and using # 10 wire. Your...
