60 amp 240 v breaker in 100 amp sub panel | on ElectriciansForums
Discuss 60 amp 240 v breaker in 100 amp sub panel in the UK Electrical Forum area at ElectriciansForums.net
Mammoth Lakes, California
Hello,
My sub panel is 100 amp (from a main of 200 amp) and it currently has a 20 amp 240 v breaker for A/C and then only lights and outlets. This is not a house, just a remote building with toilets, shower and outside kitchen.
I want to add an instant on tankless water heater that requires a 60 a 240v breaker. But it will not accept it because of the tab that stops the breaker from being completely inserted. 50 a and below work fine.
It’s a fairly new sub panel, so that may explain the tabs? Maybe related to CTL?
I’m just a DIY guy, but have done lots of home wiring including adding sub panels.
How can I solve this? Do I need to replace the sub panel?
Thanks for your help!
Jim
Hello,
Jim
The best I can tell you is install a good name brand panel with enough circuits to accommodate a 60 amp breaker.
Reply to 60 amp 240 v breaker in 100 amp sub panel in the UK Electrical Forum area at ElectriciansForums.net
