60 amp service problem | on ElectriciansForums
Discuss 60 amp service problem in the DIY Electrical Advice area at ElectriciansForums.net
and3008
2 fuse sockets on the same leg of the cartridge fuse are not working. The fuses (15 amp) do not blow - just don't have power. I have power coming from the pole and both cartridge fuses are good. The other 2 fuses on the other leg work fine. Stumped.
Reply to 60 amp service problem in the DIY Electrical Advice area at ElectriciansForums.net
Question 1 do you prefer buttered, salted or sweet salted? I'm guessing salty 😜 1. Auto range multimeter (used on mains before when testing the...
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
